how to add water to a 1985 merrilite frosty the snowman snow globe
This snow globe has sentimental value to me. The water is evaporating and I would like to add more. I did get the musical element off but can't figure out how to open up what looks like it might be an opening to the water section. (the white lid in the photo) It seems like plastic that is glued on. Any ideas?
I went with the drill hole option and it worked great! Thank you for taking the time to offer options. left empty room at the top for bubbles to escape. Just used distilled water which I put in with a syringe we had around for pilling our cats.
Yes, you will need to work that cap loose. It might break. Or you could drill a hole through it and cover with silicone glue. But you need to make the hole big enough to allow air to escape as you add new water.
You might try using a high acetone concentrate on the end of a toothpick to try to soften the glue that holds that cap on.
Yes, the whole thing is glued together. Drill a small hole being careful to catch all the plastic shavings. Then use a syringe to add the water. You can order blunt tipped measuring syringes online or get sharp ones from the pharmacy. Then seal the hole with silicone.
When drilling plastic you can do it without a drill motor. Just hold the bit in your hand and turn while pressing. You'll see shavings of plastic come off. Periodically clean them away. Then when you break through stop turning immediately and pull the bit out and you'll get most or all the shavings. You can also use a powered drill but turn the bit very slowly with light to moderate pressure so you don't blast right through the plastic.
A ink jet refill syringe with a metal needle is what I would use. Heat up the needle and melt a hole in the cover, fill, and seal. I wouldn't be too concerned with the shavings if you were to drill it open since the plug appears to be white and any shavings that got inside would look like the snowflakes already in there anyway. My bigger concern would be where the water is escaping in the first place, if you don't find that you will have the same problem again over time.
Over many, many years this is typical. The water will eventually evaporate very, very slowly thought the material. Even a closed loop radiator system will eventually need a recharge.
I'm installing a clothes hanging rod on a concrete wall. Instructions say to use anchors to hang the rod. Probably not the best on a concrete wall. Should I use tapcon screws? They wouldn't look as nice but if they worked . . . .
Suggestions?
Thanks so much
Mary
