New to automation
Old 07-13-04, 09:11 PM
T
New to automation
im looking to hook up some security cameras and be able to view on any television and a pc. What cable would I run to the tv's and the computer. i have looked at some of the sites , but still confused. any help would be appreciated.
Thanks Tearflop
Old 07-14-04, 09:05 AM
Coax will do it. It really depends on what kind of cameras you want to connect and how you want to connect them, but for the most part, you can send any kind of signal over coax. You may also want to run a Cat5 just for future use.
The easiest way to do something like this is to use a modulator to, essentially, "take over" a few of your cable channels (selectable) to view the cameras from any TV in the house.
If you use an RCA video (composite) signal, you could just connect to the TV's/Computer's video in. I personally like the modulators.
Good luck!
Old 07-14-04, 08:40 PM
T
Sounds good,
Thanks for the input.
Can I also view the cameras thru the pc
thanks
Tearflop
Old 07-15-04, 04:02 PM
That all really just depends on the type of cameras you use and the hardware you install. Of course, there are ways to do anything you want.
Good luck!
