TV Antenna
Old 10-26-05, 07:51 AM
Ramrod48
TV Antenna
Hello , Have a question about TV Ant. , Iam in Florida , so its pretty flat land , Is there a rule of thumb as to the min an max of the height of the Ant .I searched a few sites on here seems there use to be a Antenna Board but its no longer available., I see where its best to run reg cable (RG-6) , or what ever its called. Instead of the ole flat 2 wire, makes sense .
Whats the deal with putting an Amp,booster in line I read where it was suggested to use a 10-20db Amp., this will be a basic Antenna , will not be motor controlled, Any thing else I should Know ? Whats the average price of an Amp. ?
Can I run several TV'S off this or just one ? Also what about a Stereo, or is it just asking too much of the Antenna , An should stick with one TV ?, Thanks in Advance for any assistance on this .......
Old 10-27-05, 11:06 AM
C
Nowadays, any antenna you get would be for UHF only, as that is where the broadacters have their digital broadcasts. I wouldn't invest in a VHF system.
