Go Back  DoItYourself.com Community Forums > Electrical, AC & DC. Electronic Equipment and Computers > Home Automation Systems and Devices
Reload this Page >
Craftsman garage door opener 200.57933 - stuck half open, trolley is half way
Old 11-12-18, 01:32 PM
SBI
SBI is offline
Hello,
This is a replacement motor. The trolley is stuck about half way between the door and the motor. When pressing the remote, the trolley moves about 3 ft towards the door (closing), then goes back to where it was, and the light flashes...a lot, more than 20 times.
Any idea what's going on and how to fix it? Couldn't find this behavior in the troubleshooting section. It's not overheat for sure, we just plugged it in.
Also, when handling the chain or the trolley by hand, the light flickers (not sure how it is related to the light and why would it flicker as if there is a loose wire that is connectong the chain to the light.
Thanks.
Old 11-16-18, 05:51 AM
SBI
SBI is offline
Anyone?
Old 11-20-18, 12:27 PM
First, is the door connected to the trolley at this time? second, are the photo sensors aligned and operational. Your forward - back - light blinking sounds like a misalignment or a defective sensor.
Old 02-14-19, 03:48 PM
The limit switches might be way out of adjustment , even from the factory. I had that experience once. Not too hard to adjust, you have to observe when it operates, where the limit contact hits the switch. Also check the obstruction control sensors, make sure they are clean. a leaf or a cobweb could give you trouble.
Sid
