Replace dimmer with smart dimmer
Old 07-25-20, 03:09 PM
G
Hello, I have installed my smart dimmer, but I am not getting any power to the switch, or to the lights.
it is a single pole switch.
In the box I have the following wires
1 black
1 red
1 white
1 green
I have connected each of these wires to the same on the switch, and as I mentioned I am not getting any power to the switch or lights.
any help would be appreciated
Old 07-25-20, 03:58 PM
Received 938 Votes on 875 Posts
Welcome to the forums.
Was there a regular or three way switch at that location ?
What is the model number of the switch ?
Old 07-25-20, 05:33 PM
Received 17 Votes on 17 Posts
I know this does not answer your question directly but is this a commercial space or are you in an area that requires conduit (Chicago land comes to mind)? as normal NM (AKA Romex) has a bare ground wire not a green one.
Old 07-26-20, 05:32 AM
G
Thank you for taking the time to reply.
The old switch was also a single pole, I will attach an image of how the old switch was wired if that would be helpful.
This is a residential install, located in Ontario, Canada
Old 07-26-20, 05:36 AM
G
The model of the new smart switch is
Leviton Decora Smart DW6HD
Old switch wiring
Old 07-26-20, 10:19 AM
How did you know you weren't getting power to any wires ?
Either red or black...... checked to ground should show power.
Your old switch just shorted black to red to make the lights operate.
Whichever wire shows power is LINE/hot.
The other wire is LOAD.
If you get a voltage measurement from red or black to ground but not to white....
that would mean the white is not connected at the other end.
Old 07-26-20, 11:52 AM
G
I knew I was not getting power to the switch, because the led lights on the switch were not on. Also, when I flicked the switch on, and tried raising the lights up, nothing happened.
Old 07-26-20, 02:27 PM
If you are missing the neutral.... white wire is not connected..... the switch will act as dead.
Old 07-29-20, 10:19 AM
scoob8000's Avatar
Received 1 Vote on 1 Post
Try reverse your red and black wires? Whichever one is hot coming from the breaker needs to go to the line terminal on the switch.
