Trying to open garage door by WIFI
I am trying to open a garage door with WIFI. My mother-in-law needs help and am looking to have the people come in through the garage door. There is a single push button that already opens the garage door. Would there be a simple way of just being able to attach a product to trigger the door to open and close? I am trying to work with 4 of her kids to help as much as I can.
Need a hub.
Does she have Alexa ?
wifi garage door controller
She MUST have blockage sensors as door can be closed without being there.
If your mother-in-law has WIFI in her home, you could always use a Gosund outlet plug controlled over your smartphone. Plug the Gosund into 120V and power a 120V relay into the output whose dry contacts are across the pushbutton contacts. Gosund plugs are only $6-$8 each on Amazon, I have about 12 of them deployed in my home.
Amazon.com: Mini Smart Plug, Wi-Fi Outlet Socket Works with Alexa and Google Home, Remote Control with Timer Function, No Hub Required, ETL FCC Listed (4 Pack),White : Industrial & Scientific
Question 1- Why have the help come in through the garage door instead of the front door? Are the help going to be excluded from access to certain portions of the house? Why is there a preference about the entrance?
Question 2- Would it be preferable to have a remote 'you contact ME, then I can open the door' sort of setup where multiple people /family can allow access?
It may depend on the brand and model of the GDO. On newer GDOs the switches are NOT like the old style that just provide momentary continuity. Instead, they actually produce coded multiplex signals for the various functions. So, you have to have the right switch from the manufacturer of the GDO. Even if you get the simple doorbell looking switch it has to have the circuit board that makes the open and close signals.
