do i have to replace a power cord?
I have a loose power cord on a RCA TV, Model-F25251WN, chasis CTC177AF2, manufactered in 1994.
I would like to know :
Can it be tightened or should I replace it?
Do I have to remove the back of the TV or can it be pulled out?
How do I remove the back of the TV if that's necessary?
Thank you in advance for your help
UPDATE- I removed the back! after removing much dust, it appears the cord is held in place with a plastic clip.Let me go back and state the problem. In order for the tv to come on, i have to jiggle the cord where it meets the tv. sometimes the picture is fine for days. sometimes the picture shrinks and the sound becomes a buzz-hum. however, after removing the back, the cord appears to be intact. Can you help me?
Denyse, The power cord is going to have to be replaced, the break is right at the very end at the chassis. RCA part #215576. As for the vertical and audio problems you need to have the solder joints at the tuner shield resoldered and the solder joints on U4501 resoldered.
Fred
Fred
Denyse, That power cord will have to be purchase from rca. To fix the three problems you have with this television will require discharging high voltage from the picture tube and disassembly of chassis hardware to get the sections you need to get to. If you have never work on a television or this chassis before you should take it to a shop and let them do it.
Fred
Fred
Denyse, Look on the back of the television around where the power cord is and their are two controls, the top one should be the focus and the bottom one should be the screen. You want the one for the screen, you must of move it when you were taking the back cover off or when you were putting the back cover on. Adjust the screen control just enough to brighten the picture don't over do it. Or you can call up the on screen menu and scroll to your picture controls (contrast, brightness, tint, color, sharpness). Scrolling through the menu you should find the setup screen to make your changes. Start with the on screen brightness adjustment first before moving the one at the back of the television, if you find that the picture is not bright enough then turn the on screen adjustment back to where it was and adjust the screen from the back of the television. The other two problems (vertical collapsing and hum in the audio) are just warnings that EEPROM is failing due to cracked solder joints at the tuner shield. When it does fail it will shutdown the television until the problem is corrected.
Fred
Fred
Denyse, Your setup menu should have that imformation and your manual too. If you lost your user manual go to: www.rca.com
They may have a copy under your model you can download.
Fred
Fred
