Hitachi Projection TV image problem
Old 08-11-02, 08:31 AM
ywenz
Hi, my 6 year old 50" Hitachi Ultravision rear Projection has started to give me problem in the last few months. The symptom is as so:
Horizontal scanlines shows up on the left and right side and image distorbs in a zig zag patter along the scanlines. Image brightness also flashes sporadically. Image color and convergence is still good however. What's causing this? It seems almost that a connection is loose or something. Is this a common problem? And how difficult is it to fix?
Thanks
Old 08-11-02, 09:33 PM
FREDDYG_001
ywenz, Whats the model number and date of manufacture of this television? This imformation is located on the back cover.
Fred
Old 08-11-02, 10:46 PM
ywenz
Why is that needed? I just got home and it's late now I'll try to move around the equipment tomorrow and have a look, but is that a very important piece of information for this problem?
Thanks
Old 08-12-02, 07:19 AM
FREDDYG_001
ywenz,That imformation will allow me to check any tech tips I may have on that chassis that pertains to the problem your having.
Fred
Old 08-15-02, 09:03 PM
ywenz
Hi Freddie, its a 50UX26B V6H019246
It was built August 1996
any help would be greatly appreciated
ywenz
Old 08-17-02, 02:18 PM
FREDDYG_001
ywenz, I check the tech tips I have on that model and serveral other models, your problem is not mentioned. Is there anyway you can take a snapshoot of that picture and email it to me?
Fred
Old 08-17-02, 08:45 PM
ywenz
Freddie, I'll try but mean while heres a post on newsgroup from someone else with the same problem. Maybe he explained it better than I.
This 50" rear projection set has developed some
jitter and wave effect on the lower half of the screen.
It seems to be more noticeable with text on screen.
Problem is not there all the time,and auto convergence
has been done.Does it sound like a bad cap in the vert?
David I know you see alot of these,what do you think?
Thanks...
