TV rookie needs help
Old 08-11-02, 08:11 AM
auntie_biotic
I have a ferguson tv model number 59P7A. Initially the problem was horizontal lines over the top 1/4 of the screen. I phoned a technician with allegdly "26 years of experience" who said the problem could be fixed at home. After one hour he took away the tv saying he did not have the correct
parts with him. The tv was returned five days later repaired. However after 2 hours the picture cut out and the screen went blank. This has been happening with more frequency. Finally On switching the tv on the red channel number 8 flashes 3 times then nothing I would be grateful for any help.
Old 08-11-02, 09:07 PM
FREDDYG_001
auntie_biotic, I need all the imformation off that label where you got the model number from.
Fred
Old 08-12-02, 08:48 AM
auntie_biotic
Thanks for replying the only numbers on the back of the tv are as follows:
GAO 59P7 and
552913
I hope you find it useful
Thanks
auntie_biotic
Old 08-12-02, 12:14 PM
FREDDYG_001
auntie_biotic, Then only two things I can think of is horizontal circuit is in shutdown or the power supply is shutdown.
Fred
Old 08-12-02, 12:32 PM
auntie_biotic
Thanks for your reply but could you tell me what you mean. As you can tell I know nothing about tv except how to use the on off button.
Old 08-13-02, 10:58 PM
FREDDYG_001
auntie_biotic, The power supply produces voltages for the horizontal circuit and the high voltage transformer to operate. The high voltage transformer produces voltage for the vertical circuit. Those lines in picture were probably due to one or two componets in the vertical circuit going bad. If in fact he was in the vertical making his repairs he will need to back track on what did. Normally the vertical circuit shutting down does not affect the operation of the other circuits, the television will still play but you'll have no picture just a black screen with a white horizontal line running across the screen. The flashing eights might be the failure code for shutdown.
Fred
