part number
Old 08-19-02, 06:55 PM
B
part number
part number for a
RCA M.N P46733AT
C-N PTK178LA
Part location is Q4502 VERTICAL cap 25v 1500uF
any help would be great
thanks
Blackie
Old 08-20-02, 06:02 PM
FREDDYG_001
Blackie, I don't have the rca part number on that cap but, you can do this instead. You can use a 2200uf@35volts or a 1000uf@35volts and a 470uf@35volts, connect those two in parallel. What part of the board is this capacitor located? That was'nt you recently over in the tech-assist forum?
Fred
Old 08-20-02, 06:48 PM
B
yes it was
it was probably me, i got that cap checked it was good
i'm taking tv repair and almost done and i'm never going to get
this one big tv working LOL
I HAVE or it seems i have, checked everything 10 times over
the only thing i have'nt really checked is for open fuseble resistors
because i'm not quite sure how to tell if they are open
can you help me there
blackie
Old 08-20-02, 07:55 PM
FREDDYG_001
Blackie, I have not given up on this tough dog, every now and then one comes along. This is the nature of the business. You check low value resistors the same way you check high value resistors. For example if you have a 1ohm resistor and it reads 300K or higher on your meter then that resistor has change value due to a short in the circuit.
So you did check for the 5.1volts at IR PICK-up, was the voltage there?
Fred
Old 08-21-02, 08:32 AM
B
IR PICK-up
I can find it on my paper but I can't find the place on which broad
IR PICK-up I mean
but I did find the Diode run .33.7 to be bad
do i have to order that or can i just sub it
and would know the sub i have alot of diodes
blackie
Old 08-21-02, 09:26 AM
FREDDYG_001
blackie, The IR(infrared sensor)is mounted on the front panel control board next to the function buttons.
Fred
Old 08-21-02, 09:29 AM
FREDDYG_001
Blackie, Whats type of diode is it, general purpose or zener?
Fred
Old 08-21-02, 10:06 AM
B
general purpose
it's a general purpose diode the little black with the silver band
cr4118 and cr4119 they are .33.3
and i'm getting .448 on one and .446 on cr4119
blackie
Old 08-21-02, 12:24 PM
FREDDYG_001
Blackie, What do you mean by .33.3?
If your read is .448 in one direction and you check the other direction and get a higher read then the diode is not blown. If the read is zero or slightly above in both directions then it is blown. If it shows no read then it is open. There is a possibliy the diodes are leaky under load.
Fred
Old 08-21-02, 12:43 PM
B
Diode
.448 in one direction and nothing in the other direction
on my paper it's
CR4118 and CR4119 They are +33.7 RUN
blackie
Old 08-21-02, 02:40 PM
B
The IR(infrared sensor) is running infinity
blackie
Old 08-21-02, 06:06 PM
FREDDYG_001
Blackie, Are you getting a 5volt read anywhere on that board?
Fred
Old 08-21-02, 07:29 PM
B
5volt
5volt==no
+5v i'm getting 2.0
+10V i'm getting 0
+12v i'm getting 0
AC IN 26.9
BLACKIE
Old 08-21-02, 10:55 PM
FREDDYG_001
Blackie, Now were getting somewhere. Power supply problem. Anyway you can take a snapshot that chassis and email it to me?
Fred
Old 08-22-02, 06:41 AM
B
chassis
ok Fred I hope this is a good shot
blackie
Old 08-22-02, 10:24 PM
FREDDYG_001
Blackie, Which email address did you send it too?
Fred
