Zenith Sentry II SJ2726EWS
Old 08-26-02, 01:25 PM
bmarrison
This TV is a 27" Console. Here's the problem- after the TV has been on for a few minutes, I get these "lines" that go sided to side on the picture. When these lines are on the picture, there's a buzzing sound. The lines come & go and are stay longer when playing the VCR or going into Menu mode. Also, the lines go away briefly if I hit the top of the TV (I know, not a good thing to do). Thank you for your help. Bill.
Old 08-26-02, 03:40 PM
FREDDYG_001
bmarrison, If you can smack it you probably have some cracked or burnt solder joints on the main board. Check the power supply, and flyback area of the circuit board. And also check the solder joints on the crt module on the neck of the picture tube.
Fred
