JVC TV Problem
Old 09-05-02, 02:32 PM
wavel
Question JVC TV Problem
My JVC TV has developed the following problem:
Thin horizontal red lines are visible stretching from one side of the screen to the other. Consecutive lines are joined by a red diagonal line as per the letter Z.
It's just out of the warranty period of course so I'd like to have an idea of the problem before I call the service centre.
Thanks
Ian
Old 09-05-02, 04:10 PM
FREDDYG_001
Whats the model number and date of manufacture of this television?
Fred
Old 09-05-02, 10:54 PM
Smokey
Thumbs up
The red horizontal lines (usually running slightly diagonal) are called "vertical retrace lines". The usual cause of this problem is a failed capacitor in the vertical oscillator circuit.
You can read more about this failure at:
http://an.hitchcock.org/repairfaq/REPAIR/F_tvfaq.html
Check out Section 25.11 for more information.
Smokey
Old 09-06-02, 11:45 AM
wavel
I'm not certain of the date of manufacture, I've had it for 14 months.
The model is AV-28WFR1EKS.
