wards c5 chasses or 25c542
Old 10-29-02, 01:02 PM
alva sites
wards model gnb17926 (c5) chasses .After replacing hot, set works .. set blanks off ever 3 min .checked hv hold down all check ok ,,replace regulator same prob.. thanks al..
Old 10-29-02, 05:21 PM
FREDDYG_001
That should be a magnavox chassis. Whats the date of manufacture on that chassis?
Fred
Old 10-30-02, 05:24 PM
alva sites
a magvox chasses 1984
orignal chasses no is 25c501 listed under c5 all near the same or 25c5 thanks fred
Old 10-30-02, 10:10 PM
FREDDYG_001
There are several tech tips covering this problem with this chassis. This is the most common correction as follows:
Set shuts off and comes back on immediately.
Install a [email protected] filter(electrolytic capacitor) from D470 cathode to hot ground. (+ to cathode - to hot ground. Diode comes off the base of Q470 (pulse shaper). The best place to get your hot ground is from D480 which comes off the emitter of Q470. The anode of D480 connects to hot ground.
Fred
Old 11-01-02, 01:55 AM
alva sites
c5 longer
Fred C5 plays about 30 min. after install filter & quicker flashes.
( RCA doing fine ) Thanks Any more suggrestions on c5..
Old 11-01-02, 08:02 PM
FREDDYG_001
Tech Tips as follows:
1)Power goes off for a second/Resolder grounds on outer edge of pc board.
2)Shutdown(int)/Check C401, Z402, R402, resolder T463, and T488.
3)Shutdown(int)/Q401 needed resoldering.
4)Shutdown(int)/Resolder T500-Standby power transformer(loacted on control panel).
5)Shuts down/R476 changed value. Carefully select new resistance of~115k and test 130volt line. Trim resistor as needed. Note if B+ is low, vetical foldover at top will occur. Adjust B+ higher.
6)Shuts down/Resolder C402
Fred
