Zenith 27" - everything is green
I have a Zenith 27" model SY27655.
The picture comes in fine but everything on the screen has a green tint. Changing the color settings does not make a difference, still can't get away from the green color.
Any help would be appreciated. Thanks!
Tech Tip as follows:
1)Color - R,G,B missing(not picture tube problem)./ Check Q2205,Q2206, and Q2204-replace with original or nte290a-note pins.
2)Green inop. at first now bright green./Q2205,Q5102, and C5102
3)Check 200ohm resistors on crt board for RGB pins at socket.
4)Check for any cracked solder joints at crt socket.
If everything checks out berfore or after replacing any parts picture tube bad!
Fred
Fred
