Toshiba TP48E60
Old 01-07-03, 03:52 PM
Scat30
Toshiba TP48E60
My TV died
When I plug it up the red on light starts to blink rapidly.
Any Help?
How much to fix?
Thanks in Advance
Old 01-08-03, 08:45 PM
FREDDYG_001
Tech Tip as follows:
1)Dead, LED flashing./Check for shorted pins Ic Q483 Hv regulator. Ic part #B0350510.
2)Dead, LED flashing quickly./Check Qa01 and Qa02 for damage. The damage can be caused by poor silicone seal around the high voltage caps to the crt's.
3)Dead, LED flashing slowly./Check power supply, D875 zener diode s/c. Check Q751, Stk392-110 on convergence board. Also check Q641 for rear audio output.
Fred
