Mitsubishi 31" TV
Old 01-08-03, 04:39 PM
Doug Money
Mitsubishi 31" TV
I have a Mitsubishi 31" TV, that used to have the picture get dark with lots of red highlights. Now it is like this all of the time. Used to only be occasionally. Any help is appreciated. I am a computer tech with extensive electronics knowledge. I just never worked on a tv before. Thanks for your help.
Old 01-08-03, 07:59 PM
FREDDYG_001
Whats the model number and date of manufacture?
Fred
Old 01-09-03, 06:29 AM
Doug Money
CS-3131R build date: February 1991. Thanks.
Old 01-09-03, 08:11 AM
morgan28476
Replace all 10uf, 4.7uf and 22uf minature aluminum electrolytics on PIP module. BE CAREFUL. Capacitors may have leaked and damaged the pcb traces. Replacement kit available from Tritronics. If not used, PIP module can be bypassed.
Old 01-09-03, 07:14 PM
Doug Money
I am not really interested in Pip at this time, how can I go about excluding it. I believe it is just inserting 2 capacitors? Thanks again for your help.
Old 01-10-03, 06:19 AM
morgan28476
Place jumper between pins 5 - 11 and between 7 - 9 on the VP connector. remove PIP board.
Old 01-10-03, 06:22 AM
Doug Money
Thanks, I'll try it tonight.
Old 01-10-03, 01:00 PM
Doug Money
I started on this repair. Can you give me just a little insight into which board is the pip board, and do I jumper the cable at the pip board? Thanks
Old 01-10-03, 01:42 PM
Doug Money
I removed the pip board, it has a number 930B84360, The vp connector is toward the screen on the main board. I jumper the same plug on the main board at the spots you indicated. Do I need caps for these jumpers? Thanks.
Old 01-10-03, 03:57 PM
Doug Money
I installed the caps in the VP socket in 5 & 11 and 7 & 9. Picture is no longer dark. It is a bit grainy. It is definately usable. Thanks. I used 10uF Electrolytic Non-polarized caps rated at 50volts. They did not have the 22uF, is this a problem? Thank you again.
Old 01-12-03, 11:19 AM
FREDDYG_001
That might be why your picture is a little grainy, the value you used.
Fred
