RCA TV won't power up
Old 01-13-03, 07:50 PM
Jim Johnson
When tv is powered on the relay pulls in but the set will not come on. It makes 3 attempts to start and then nothing. Any idea what the problem is and where to start looking.
Model #F27664
Chassis #CTC203AX
MFG. 1999
Any help would be appreciated.
Thanks
Jim
Old 01-14-03, 10:37 AM
K
This sounds like what my TV was doing... although I am no expert
Remove the HOT transistor, apply power, and press the power button. If it turns on and you have a static sound (no picture) you have a bad flyback transformer or the diodes around it.
Old 01-14-03, 06:59 PM
FREDDYG_001
Tech Tip as follows:
1)No start-up and pulses three times. All standby voltages ok./Replace regulator I.c. U18101 on PIP board.
Fred
Old 01-14-03, 07:15 PM
Jim Johnson
Thanks for the help. I have a sam's schematic coming and I will let you know what I find as soon as I have a chance to get into it.
Jim
Old 01-19-03, 02:30 PM
Jim Johnson
Smile
Thanks Fred. it appears that u18101 is the culprit. I pulled the PIP board and the set started up. I'll go to the parts store tomorrow and get a new regulator IC. Once again thanks for the help.
Jim
