mitsubishi CS35301 tv
Old 03-24-03, 08:57 PM
hopetofixit
Smile mitsubishi CS35301 tv
Hi Teratum, I finally got the manual for my TV and I am going to order the part.You told me by replacing the C7001 chip capacitor it should fix my problem.I went the web site you told me about and found the part I believe.the part number in the manual is 181P081O90,the description is 35V 4.7uf.The part that I found does not have the part number but it is a chip capacitor 35V 4.7uf.That would be the same part wouldn't it?If so I will order it and get this thing fixed I dont like watching the TV roll for 15min before it stops.Hope to hear from you soon so I can fix this TV. Thanks alot for the info. Gary
Old 03-24-03, 10:48 PM
Teratum
Hi Gary:
It should be the same. Replace it carefully and see if the problem goes away.
