Audio no Video
Old 03-31-03, 06:52 PM
shaffeb
Angry Audio no Video
I have a Zenith 19" TV model number SLS1919S with video problems. It is hooked through satillite dish -> vcr-> tv. I tried all buttons I can think of on all remotes. I have a picture only through vcr play. No video on network channels, just audio. Again, I tried fooling with the remotes and also tried to hook it up to the dish box in my bedroom. Still nothing. Any help would be much appreciated. Thanks
Old 04-08-03, 03:23 PM
Teratum
It sounds like there is nothing wrong with your TV but you have a problem in the tuner section of your VCR, so any signals that has to pass through VCR coax connectors can not get through. When you play VCR tape, it's ok because the signal uses different path.
Try connect dish --> TV directly if you can get picture. If you do, your VCR is bad.
