Toshiba TV Model CF3060K (foldover)
Old 04-17-03, 01:31 PM
V
This is a 30" set. It has a 4 to 6 inch foldover at the top of the picture. This set had no vertical deflection. It had a horizontal line across the center of the screen. I replaced the vertical output IC, resister FR 5.6 ohm 1 W, and two capacitors EL 2.2 mF.(red)
This brought the picture back to where I am now.
Old 04-17-03, 04:34 PM
R
rxpc
It's probably a bad cap in the vertical section. I had the same thing with a 32" Tosiba and it was c308 that fixed the same problem your having.
