JVC tv, picture shrinks to horizontal band
I have a JVC tv, model C-2018. When it is on, there is a small bright line about 1" from the bottom. Then after it has been on for just a few minutes, the bottom becomes unstable, as if the bottom 40 lines get compressed into about 5. Then suddenly the whole picture becomes a jumbled band about 1" high in the center of the screen.
I removed the back and sprayed a lot of dust with compressed air, but the problem is still there. I suspect it has to do with heat.
Any hints on how to troubleshoot this particular problem? Thanks.
VERTICAL PROBLEM
if you look on the pc board you should find transistors mounted to metal heatsinks. look on the board some are labelled vertical horizontal etc. try soldering the vertical drive and vertical output transistors as well as any electrolytic capacitors. capacitors are also a common problem in the vertical section.
hope this helps
kurt
hope this helps
kurt
