Extended run with RCA cables
I am trying to buy a 36' RCA cable for hookup of an inwall keypad with line outputs(bare wire) and a stereo tuner (RCA connections)
The question is: No one has it with bare on one end and connectors on the other. Can I cut the connectors off one end for the bare wire input and not have a problem? Someone told me that it would screw up the signal.
My instinct is that the connection will work.....Please advise...thanks...
