flyback transformer help
can any one tell me the best way to discharge a flyback transformer on a tv
i am replacing mine as it has a hole and the tv screen stays blank
It's the CRT you need to discharge not the flyback. I don't like the idea of just a wire. That could create quite a spark. I used to use my high voltage tester and keep it on until the voltage went to zero.
The average person is not going to have a high voltage probe/meter in their kitchen drawer. A simple length of wire connected to ground then to the high voltage cap works fine. At work every day I use a clip lead connected to a flat blade screw driver.
Dakota
* EDITED - DO NOT POST YOUR E-MAIL ADDRESS IN YOUR REPLIES *
Dakota
thanks everyone
i have managed to replace my flyback but the tv is still dead
i am afraid there could be more damage
i have also noticed a resistor next to the flyback which is blown
but i cannot read it but the circuit board reads R435 and i do not know where to get the exact size of the resistor
its an akai model= CKT2001
serial number= 93-21-06-024
