Panasonic Mdl#CT32D31E
Old 06-08-04, 02:20 PM
C
Question Panasonic Mdl#CT32D31E
The channel # is off the screen enough that it can't be seen,not all of it.Has anyone got any tips as to what to look for?Caps or diodes in the pin cushioning?Help,Cecil.
Old 06-12-04, 03:39 PM
rav12's Avatar
If only the no is off the screen and the rest of the pic is ok then I would guess that the fault is with the circuit/IC that generates the number and inserts it into the video signal. The circuit that does this has to be synchronized to the timebase circuit - if this goes faulty and the timing drifts you could see something like this.
If this is the case fixing the pincushion is unlikely to help.
Old 06-13-04, 06:11 PM
C
Panasonic;Pix off screen.
Hi Rav, I thank you for your input into my custmor's tv problem.We don't have to contend with it for now.Some how I got the model# mixed up.The true mdl# was a unit that was still under warranty,She 'd only had it 6 months.So pushed her to factory service.Thanks so much anyway Rav.Cecil35.
