Model No. KV27S10 Sony TV Dead
Old 06-14-04, 12:30 AM
PunkBassist
My father was watching Tv for a few hours this evening and randomly the Sony model No. KV27S10 tv died. By died, I mean just turned of and would not turn back on at all. The Wall socket had full power, and I checked the fuse, there were no problems there. Anyone have any ideas as to what might have happened or whethere I will be able to fix it on my own? Thanks for any and all help.
Jake Elder
Old 06-14-04, 12:51 AM
craigpatty
hi the problem could be the on and off switch on the tv is burnt out or breaking down
or there could be a dried joint on the transformer or power supply
i know for a fact sony stuff suffers from very badly solder joints
other then that you got to be carefull as it can give you a nasty shock
turn the tv on and just put your nose up to the switch and see if
you can smell anything burning
Old 06-15-04, 12:05 AM
PunkBassist
The TV doesn't even turn on. No smell, nothing. Unfortunately, I am at a loss as far as what I can do. Thanks for the quick reply.
Jake
