ANNOYING Television Noise
Old 07-04-04, 05:22 PM
sryder
This is my first post - but would like to become more active here!
I have a 27" RCA television that is about a year and a half old with an RCA Receiver, DVD and of course VCR.
About seven months ago there started a noise that has become more annoying over time - so looking for a solution.
It occurs after the television has been on for about a half hour once warmed up. The sound is honestly tough to describe - not humming, not buzzing, not snapping, not whistle - but present. Sometimes it does go away but will come back eventually...
I had thougt it may be the receiver but with that off it still makes the noise. I had speakers close to the television and moved them away, no change. It isn't the speakers on the set, but sounds more like coming from inside the set and an electrically issue.
Not sure if there is much that I can do but looking for some advice on how we can correct this!
Old 07-06-04, 02:35 PM
snuffs's Avatar
you already have troubleshot the units to the tv, so you are more than halfway there. intermittent problems are some of the toughest problems to find. it may be just bad solder joint, or more serious.if you take it to a repair shop it may take quite awhile for them to find it.
since it is acting up more frequently, a repair shop should be able to find it.
good luck snuffs
