vcr tape "sticking"
Old 07-15-04, 04:16 PM
dr.evil
vcr tape "sticking"
My VCR has been, on and off, been taping programs that playback with little audio/video blips. It is like the tape is getting stuck for a split second, the audio/video jumps a bit...and when it does happen, it will happen throughout an hour or two of taping. It seems to be worse at the beginning of the tape. Is this a tape problem (I've tried a couple different ones though) or does something need to be "tuned up" inside the VCR?
Anyone else have a similar problems or suggested solution?
Old 07-16-04, 12:13 AM
rickt737
This symptom often appears if the capstan motor is failing or if there is a fault in the servo system. I don't know the make of your vcr but Sony's often exhibit this problem. Good luck.
Old 08-05-04, 02:12 AM
Terahertz
woah people still use vcrs? yeah rickt737 is right, check the motor first, since if this is the problem it will be the easiest to determine and repair/replace, if its your servo system, you maisewell get a new vcr, their cheep now anyway.
