RCA 27" TV - Picture Size
Old 07-16-04, 12:19 AM
deankubiak
I have a 27" RCA TV about 5 years old. The picture on the screen is great, however, in many instances the edges of the images on the screen are cut off. I can tell this because from time to time when the credits role or there is text on the screen in a movie or program the text is cut off. I've tried playing around with the on-screen adjustments but there doesn't seem to be any adjustment for picture size.
Any suggestions? Thanks!
Old 07-25-04, 03:27 AM
snuffs's Avatar
which sides are crunched, the to bottom or the sides?
Old 07-30-04, 07:18 AM
deankubiak
Thanks for the reply Snuffs!
It is the sides. I do not notice it top to bottom.
Thanks!
Old 07-30-04, 03:34 PM
snuffs's Avatar
you may have to get in service mode, usaully three keys pressed at the same time, contacting rca for the codes may be necessary. then the horizontal width would need adjusting. Also Check your incoming line voltage, ( voltage aviable from recepticals), if it is too high, that also could cause this problem.
good luck, snuffs
