demagnatizing tv
how can i demagnatize my tv with the things i have around the house? i saw one person talking about using a solding gun . what does that do for it ? thanks
The way to demagnetize the TV is with a coil. You said you wanted to find something around the house. Do you have an extention cord that is maybe 50ft or more. Coil it up in a tight circle with a diameter of no more that
10 inches. Wrap tape around it to secure. Leave about 6 ft so you can plug it in. Then slowly move it around the picture very close to the tube and then in a constant circular motion bring it away from the tube.
demagnatizing tv?
You should not have to do this,as all new tv's and computer monitors do this when you turn them on.
If you have a color problem,try turning the set on,then off a few times.
If that don't work,you'r set needs more in-depth service.
Good luck.
Good luck.
zigzag's suggestion of using a coil of extension cord would need to have a high current device, like a 1500 watt heater plugged in to allow the current flow to create a flux.
