wiring speakers
Old 01-07-05, 11:35 AM
rotochmp
wiring speakers
Is there any problem with running speaker wires (say for rear speakers) through the same holes that I've drilled through my basement trusses? I was concerned that there could be interference as they run together through a tight space. Would I be better off running them through separate holes as I lead them form the edge of the room to the middle of the room where I would separate them to run to their respective speakers?
Just wondering,
COLOR=Plum]undefined[/COLOR]
Old 01-08-05, 08:06 PM
D
I think that this post
has basically the same information that you want to do, here it is: http://forum.doityourself.com/showthread.php?t=195433
I hope this helped!
Old 01-08-05, 09:12 PM
As long as you don't run them through the same holes as AC wiring, you're fine. You won't get crosstalk between speaker wires.
Good luck!
Old 01-10-05, 08:43 AM
rotochmp
Thanks!
Thanks for your advice guys.
Old 01-15-05, 04:19 AM
Another thing to be aware of is that some speaker wire is designed for "in wall" use and some is not. I'm not convinced it makes a big difference, and have used non "in wall" wire in walls w/o a problem. YMMV.
