321 boise system
Old 01-17-05, 02:26 PM
daniel.johnston
321 boise system
Several weeks ago I dissconnected my system (working just fine) Today I set it back up and it will not turn on. I have check all connections several times, I just can not understand or believe it won't come on.
Old 01-18-05, 01:44 PM
K
make sure its plugged into a receptacle that you know is working. Also, there is probably a master switch besides just the power button. Mine (Harmon Kardon) has a switch that you're supposed to hit in an electrical storm to COMPLETELY disconnect the power.
Old 01-18-05, 11:54 PM
Mayeb an internal fuse? I would call Bose on this one, you pay enought for their stuff you'd hope they had decent post sales support.
Old 01-19-05, 08:34 AM
daniel.johnston
321 bose
the company has ask that I sen the unit in and are charging me $190. to refurbish. They said the unit is dead, what ever that means. I looked at the fuse that is soldered on the circut board and it appears to be fine and have checked for power at the plug end going into the unit and all is good. So OFF to the factory I guess I will go.
Old 01-21-05, 12:02 PM
Personally I'd spend my $190 on something else.
