How to calculate signal loss when using a combiner?
1-Please need help to figure out how to calculate the loss when using a 2-way combiner (diplexer). Assuming that I have two leads that I want to combine; OTA signal 14 dB and satellite signal 24 dB; the loss would be -4 dB. From which number I subtract 4, from 14 or from 24?
2-Also, it is absolutely necessary to have the signals to be combined of the same level (or very close; how close?) or they can be like in my example (14, 24)?
3-If they have to have the same level, how I do that?
Thank you
Mark
Thank you
Mark
Thank you
Mark
Thank you
Mark
Also, to get the true loss you really need to calculate the cable loss at each frequency and each connector will typically add about 0.1dB loss to the path.
Ok, it makes sense now to treat them individually. Hmm, to calculate at each frequency becomes too difficult for me. Anyway what do you mean "each connector"? You mean every F connector? Those also creates losses? Anyway I guess they are negligible being so low.
