Splicing outdoor speaker
Old 06-02-05, 02:34 PM
I would like to set up outside speakers on my deck. How do I go about splicing a wire from my current speakers in my audio system to outside?
Old 06-03-05, 11:29 AM
B
Do not just "splice" the leads. You will lower the ohms and probably damage all the speakers and the amp. If you hook up two 8 ohm speakers in parallel, you reduce each to 4 ohms. Only mid-priced and expensive amps can handle 4 ohm speakers.
You need a speaker selector switch - available at most electronic stores.
Old 06-03-05, 01:22 PM
Thanks
What is a speaker selection switch? In the back of my reciever there are no more places to put any wire in.
Old 06-04-05, 11:58 AM
B
Its a separate box. You wire two leads into the input and then can connect up to 6 pairs of speakers. Units are available in 4 and 6 pair. Inside is the necessary circuitry to prevent damaging your speakers and amp.
Old 06-04-05, 04:55 PM
Thank you so much for the help
