turntables
does anyone either know how to fix or knows of a web site which tells how to fix old turntable? I have several old ones and would like to get them working in order to play my records. Thanks
Well I did a little research and found out that I can get belts for turntables but that's about it. They are so old that it's almost impossible to find parts except for broadcast grade TT's but even that is becomming harder and harder to find. So with all this said, what are they doing? What I used to see allot of was old grease. Clean out the grease and put on new belts. Company called TRI-Tronics (on the web) still has needles and belts but not much more. Look around the web, you maight come up with some old timer that has parts is there is a mechanical problem. Later...
