6 channel analog or digital coax from DVD?
Old 10-04-05, 10:11 AM
hi
i just set up a home theatre system. generally speaking i have a sony wega LCD HD tv; onkyo receiver, polk audio satellite speakers and a toshiba DVD player.
my first question (there will be others) is: i have hooked up the DVD audio with the 6 channel analog outputs. however, i could have used the digital coax and possibly the optical "bitstream" output.
which is better?
thanks
Old 10-04-05, 01:00 PM
I would have to say use a digital connection. Or the optical if you want to spend the $$ for a cable.
Old 10-04-05, 01:19 PM
do you have a reason for thinking digital over the 6-channel analog?
Old 10-04-05, 07:22 PM
I've have both analog and optical connected to the same DVD player and can't really tell the difference. Perhaps I'll try several DVDs and switch between analog and digital inputs to see if I can tell a difference. But that won't be for several weeks.
I use the analog for listening to DVD-A discs. "Brain Salad Surgery" is simply awesome!
Old 10-05-05, 05:57 AM
last night i purchased the coax cable. it seems fine.
i was a llittle worried that one of the rca cables for the analog wasn't working well so i decided to simplify the connection by using just the one coax instead of the many for the analog.
i don't have that "brain salad surgery" so maybe i won't need the analog.
one other question though: do i set my DVD to "bitstream" or "PCM" as the output?
i don't even know what PCM is.
thanks
Old 10-05-05, 06:17 AM
My reason for the one coax is just that, 1 cable vs 6. Less of a spiders nest.
Set your DVD to PCM.
PCM = Pulse Code Modulation
If you have time, do a search on bitstream pcm
Was not able to find anything recent but this kinda explains the difference.
www.meridian-audio.com/ara/bitstrea.htm
Old 10-05-05, 07:02 AM
thanks. will do!!!
i must say, i glanced at the link you sent and the terminology went right over my head. but, i will read more and see if i can figure it out alittle.
i set my dvd to bitstream because i thought it sounded better than PCM. but, i will experiment.
is bitstream more for optical or does this have nothing to do with it?
thanks
Old 10-05-05, 10:31 AM
i did a search and found this link.. easy to understand and informative:
http://forums.audioholics.com/forums...hp/t-7746.html
Old 10-05-05, 11:38 AM
Thanks for the link.
I will have to check my statement on the bitstream/PCM setting.
Also need to see what mine is set to.
BobF would know for sure which is best.
