Correct Settings Onkyo Txsr600
Old 10-10-05, 02:51 PM
Help with input settings.
I have a new Panasonic DVD player connect to the receiver via a coax digital cable. What should the settings be for input. Basically all the settings in the on screen display.
I have now connected my Dish Network to the recievier via an Optical digital cable. What are the settings that I need for this on the OSD.
Any help will be appreciated.
Thanks.
Old 10-10-05, 05:35 PM
You want to assign the digital coax to the DVD and assign the optic to whichever input (my sat is vid-3) you have the sat input.
Set the audio input on the receiver to auto so it will use the digital input when such a signal is present.
Old 10-10-05, 06:11 PM
What should the Analog/PCM source be set at? Surround?
PCM fs 96khz source be set at? Direct?
What exactly are these setting and what do they do? No Clue.
I'm sure there will be more questions. Thanks for the help.
