dvd/cable/tv setup
Old 11-30-05, 08:20 PM
jeffreymarc2
dvd/cable/tv setup
I have a Philips DVDR615/37 Recorder/Player. I used to have it connected to Cable/TV and a VCR. I removed VCR and now I cannot access DVD menu to set clock, play or record DVD's etc. I have it connected as follows:
Cable Box Cable Out to DVD Antenna
TV Antenna to DVD TV
Cable Box Audio/Video Out to DVD Audio/Video In
Does anyone have any suggestions as to what I may be doing incorrectly?
Old 12-01-05, 01:36 PM
Ladyfixer's Avatar
DVD help
Can you see the DVD screen on your TV? You should have audio/video out line from DVD connected to audio/video in of TV. Then you should have TV set on Video 1 or 2 - if older TV use aux (zero) +1. Make sure remote is pointed towards DVD player and that DVD button is pressed. Hope this helps, The Ladyfixer.
Old 12-01-05, 05:33 PM
TV antenna to DVD TV is the connection from DVD out to the input on the TV? I've never seen a DVD recorder nor player with a coax output.
I looked up the manual (you still have your manual don't you?). The coax cable is only good for watching cable. Its not for use when watching a movie.
Hook up the yellow, red, and white cables to watch a movie.
