RCA P46924 46" Wont power on. Getting clicks.
First off, the model is p46924 and the chassis no. is PTK195MA
I garbage picked this Tv about 7-8 months ago hoping to get it repaired. When I plug it in and press the power button, and it makes one initial click, followed by 3 additional clicks. im not sure if click is the right word, it kind of sounds like a pop or thump from the front of the tv. I've opened it up, the fuse on the main board looks fine. I didn't see any loose connections or any broken components.
so if anyone has any clue what is wrong or what could be wrong, and if I can easily replace the components myself or if i need to get a repairman to come to my house and just check out the tv. because like i said, i garbage picked it, so for all i know, it could have a whole bunch of problems besides the not powering up problem.
Thanks for all of your help in advance.
p46924
The TV you have is an RCA model p46924. Some of the RCA models had a problem with the FLYBACK TRANSFORMER.
This part has a higher failure than most.
RCA
PS50700
CTC195
Dead, LED blinks intermittent
Flyback, #239111
Comments:Tries to start 3 times (base of output). Unsolder collector, stays on & has sound. Replace flyback
Also Try
http://www.tritronicsinc.com/cgi-bin/onramp.exe?pgm=itemdet_cs.bbx&custnum=RETAIL&password=1138058445&id=239111
This Plase Might Have What You Need.
http://gallery.bcentral.com/GID5148955DD524694-Flybacks.aspx?SearchString=239111&SearchButton=%26nbsp%3Bsearch
RCA
PS50700
CTC195
Flyback, #239111
Also Try
