vcr/cable box connection
Received 0 Votes
Hello all....just changed some things around in house...now have a vcr and a cable box...cannot get vcr to tape off the incoming signal...vcr plays existing tapes fine...taking my history into consideration..I probably have something wired wrong..or a switch not in the right position..or something else simple..any help would be appreciated....thanks
Your wiring should be as follows to tape off the cable box.
COAX from wall to CABLE IN on cable box
Then have COAX go from CABLE OUT to IN on VCR
VCR OUT to TV IN.
Remember to have VCR on channel 3 or 4, which ever it is set too.
VCR OUT to TV IN.
Received 0 Votes
And the vcr/tv switch MUST be set to VCR. If its set to TV, you are bypassing the VCR tuner.
You must also set the channel to be taped using the cable box. The TV and VCR is always set to channel 3 (or 4 in some areas). The cable box does the channel switching.
Say you want to tape Dresden Files on SciFi Monday at 1:00 a.m. You set the timer on the vcr to record channel 3 (see above) for Monday at 1:00 a.m. Then you either make sure to leave the cable box on the SciFi channel or set the cable box timer to switch to SciFi at 1:00 a.m. Monday.
Or get a DVR and make life simple.
