Cable in 2nd bedroom...
Old 01-30-07, 03:20 PM
Super Papa's Avatar
Guys,
I'm installing a tv in our guest room. I already have an outlet in there (it was installed when our home was built), but it's not receiving a signal. I took off the plate to confirm that there is actually a cable coming in, and there is.. Is there something else that I need to do, or that I can do? I should'nt have to have the cable company come out, right?
Old 01-30-07, 03:55 PM
mango man's Avatar
you need to find the other end of that cable
look in the attci or crawl space
chances are it will need to hooked into the system
Old 01-30-07, 04:07 PM
HotxxxxxxxOKC's Avatar
To add to mango's post:
It might be disconnected in the main cable junction box on the side of the house as well. Can you observe through the receptacle if the cable goes up the wall, or down? If it goes up, look in the attic like mango said, if down, look in the basement.
Old 01-30-07, 05:59 PM
Super Papa's Avatar
Thanks guys. I'll have a look tomorrow, and get back with you.
