RG6 for satellite vs RG6 for Cable TV?
Old 04-11-07, 08:40 PM
Is there a difference between RG6 for satellite TV and RG6 for cable TV? I've moved into a house that used to have satellite, but I now have cable TV. I've used the existing RG6 cabling to hook everything up, but was wondering whether there was any issue with using the RG6 that's already laid - some of the RG6 have the words Digital Satellite Cable on the sheath, but as far as I can tell, it's still RG6 and appears to match the normal cable TV RG6 I'm used to. Is it just a marketing gimmick, or is there a true difference? Thanks
Old 04-12-07, 07:10 AM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
It's the same stuff.
Old 04-12-07, 08:23 PM
fewalt's Avatar
Any RG6 will work for cable. They used to use RG-59
RG6 for Satellite should be factory swept tested for carrying higher frequencies.
Yeah, the wording you see is sorta a marketing gimmick(but it prolly was swept tested)
Sorta like vhf/uhf antennas these days. - they now put Digital TV on the antenna box.
fred
