S-Video Cable Question
Old 05-02-07, 04:41 AM
F
I ran all my cables through the wall from my 50" Pioneer plasma to my Bose Lifestyle media center. When I play a DVD, it displays black and white???
Could my S-Video cable be bad?
TV displays in color with cable box. And the Bose system work perfect on old TV.
Any thoughts?
Old 05-02-07, 05:27 AM
B
Maybe try using a different s-video cable, try the s-video cable with different devices like a different dvd player or a different TV, try looking through TV and dvd player settings menus to check that they are both set to PAL or both set to NTSC.
Old 05-02-07, 12:51 PM
I had the same problem recently and discovered that one of the pins was bent in my cable. Try a different cable or look inside either end of the cable to see if all the pins are straight.
Good luck.
Old 05-03-07, 04:30 PM
B
Yes - I had to replace my s-video cable a couple years ago.
Old 05-03-07, 06:59 PM
fewalt's Avatar
Why in the world are you watching a 50" Plasma using S-Video????
Please get DVI/HDMI/Component cables.
Old 05-03-07, 11:44 PM
core's Avatar
I agree with the suggestions to try a different s-video cable. However:
In my particular TV I get black and white video if I do not select the proper line input. I have inputs for AV1, AV2, and SVID. It seems the av2 and svid circuits are shared behind the scenes, so if I plug in an svid cable and mistakenly select AV2 on the TV I'll get black and white video. (One would expect it not to work at all.) Just thought I'd throw that out since this seems to be a new setup for you.
Old 05-15-07, 10:55 AM
F
Smile
Thanks!! This was the problem. Straightend the pin out with a pair of tweezers and everything works great!!!!
