Hooking up a dvd/vcr combo
Help I got a sylvania dvd/vcr combo and having a heck of a time. Can some one tell me in what way do I hook this player up to the T.V. .. Thank you
If you want to record programs on the VCR, you'll also need to disconnect the incoming cable line from the TV. Connect it to the "In" of the VCR/DVD and run a jumper (usually included) from the "Out" to the TV.
You'll need to give us more info. What connections are on the back of your tv - just a cable connection (coax?)? Does it have red-white-yellow (rca jacks) inputs? S-video?
What input do you have - cable, satellite, antenna?
What have you already tried and what worked/did not work?
