Diplexer for sat.
Old 06-18-07, 12:17 PM
Diplexer for sat.
Just moved into a new house and the sat. guy installed a new dish. I told him I had been using a splitter and A/B switch to get sat. in 2 rooms. He installed a diplexer to my main tv and at the service box. I thought it would split each of 2 sat. boxes to 2 of 4 tvs. Living room/master bed & daughters bed/ guest bed. Instead it splits the living room feed to master and guest bedrooms and daughters feed is her room only. Do I need diplexers for her sat box to make it work in guest bed?
Old 06-20-07, 05:47 PM
fewalt's Avatar
Possibly..... you will need two more diplexers: one at your daughter's sat receiver and one at a central point which goes to the guest room.
OR, Split the modulated output from her receiver and send it to both sets via coax.
Or, use Composite video at the sat box for her TV, and run coax to the guest room.
Do what is the easiest for you,
fred
