mounting screws for flat panel
Old 08-12-07, 09:29 AM
R
Bought a Flat LCD 37"(Vizio)...no screws for the back to mount to a bracket, and low and behold the bracket says refer to the TV box for the screws!....what are the types of screws that screw into the TV to mount??
Old 08-12-07, 09:40 AM
HotxxxxxxxOKC's Avatar
Each model is different.
You will probably have to measure the TV's mount bolt holes to make sure you get the proper size screws.
Here is a document that may help.
http://www.vizio.com/media/accessories/pdfs/IN-VMA4260.R1.pdf
Also look in the paperwork that came with the TV. It should show the parts list with it listed.
Old 08-12-07, 05:50 PM
fewalt's Avatar
If the TV is VESA compliant, like it should be, most vesa lcd mounts probably come with the proper srews.
fred
Old 08-19-07, 12:16 AM
Integrator97's Avatar
All the mounts I've bought came with screws, and I've bought plenty. What brand of mount is it?
