cd player scrolls m-error
Old 08-30-07, 01:02 PM
my fisher 24 cd changer scrolls m-error when i try to play a cd
Old 08-30-07, 03:24 PM
HotxxxxxxxOKC's Avatar
Probably not worth repairing but;
M-Error = Mechanical errors can be any number of things. In some cases a gear is stuck, in others a part has jammed. Sometimes, a CD is positioned wrong or has fallen off of the carousel, causing the platter to not turn. One way or another, something mechanical is inhibiting the operation of the unit. Without being able to look inside and see what's causing it, that's about the best diagnosis someone can give.
I'd be willing to bet there is a busted gear underneath the carousel, which seems to be the most common issue with Fisher CD 24 disc CD players displaying a mechanical error. While it is possible to fix this yourself, you'd need to completely take apart the CD player, diagnose the exact problem, attain the parts, replace the parts, and put the unit back together again. Not an easy task unless you're really into this stuff, otherwise take it to a service center for repair, or head out shopping and replace it.
