Lnb
Lnb
Can anyone tell me how to test the LNB's on a dish 500? I have two extra dish and cant get them to work.This unit is in a camper and only uses one cable,which connection does the cable hook to.
Thanks Ed
Thanks Ed
Are you using a switch? For the initial setup, the dish output has to be connected directly to the receiver. Install the switch after you have verified signal.
Also, you need to check compatibility of the dish and receiver to make sure they'll work with each other.
The Dish Network Tech Portal is a terrific resource.
