Generic versus Leviton splitter?
Old 11-16-07, 03:29 PM
G
I am about to purchase a 1X8 splitter for my cable TV. I have a Leviton Structured Media Panel, so I was going to by the Leviton model made for my panel. I think the angle of the splitter will make it easier to make my connections. Here's the splitter:
http://www.smarthomeusa.com/Shop/Str...Item/47690-8C/
But the price of the Leviton is more than 4X the price of a generic 1X8 splitter:
http://www.mcminone.com/product.asp?...me=MCMProducts
I don't mind paying the extra money if it is a better splitter.
Any opinions are appreciated.
Old 11-16-07, 03:36 PM
HotxxxxxxxOKC's Avatar
I thought only Leviton splitters work (fit) in their panels?
The one's from your second link look.....cheap IMO.
Old 11-16-07, 03:44 PM
core's Avatar
They do look cheap, and for the small price difference we're talking (
Old 11-17-07, 04:09 AM
R
Received 1 Upvote on 1 Post
I'd stay with the Leviton. It will make a nice clean installation and easy servicing. Pick up the 48210-VA amplifier while you're at it. The splitter loss is 10dB or so at digital cable freqs, which will probably affect the signal quality.
Old 11-17-07, 04:23 AM
G
Thanks for all replies. I will go with the Leviton.
Old 11-17-07, 01:32 PM
F
I buy from MCM on a fairly regular basis. While I did had a problem with a wireless keyboard I find that most of what they sell IS high quality merchandise.
In fact, right now I am using a cable splitter, right-angle "F" connector adapters and "F" compression connectors that I purchased from MCM. I have also used an RF amplifier from MCM that worked quite well, whereas the Leviton amplifier did not work at all.
Old 11-17-07, 02:16 PM
R
Every manufacturer delivers a bad part every now & then. Generally, though, I've found that sticking with name brands not only decreases the out-of-box failures, but also provides much better customer service if there is a problem.
If a brand-name part costs $10 and a no-name knock-off costs $5, I have to wonder where they skimped.
I do know that we changed suppliers and used cheap RF splitter/taps for one installation (a high school). We had a lot of failures early in the warranty period and wound up replacing all of them.
Old 11-21-07, 12:05 AM
Integrator97's Avatar
Part of what you're paying for is the bracket to make a nice clean install. The Leviton is probably a better product then the Blonder Toungue, but it's not junk.
I'd do a little research. Typically these modules will fit in other brands enclosures. On the Smarthome sight ChannelVision has some for about 12 bucks. And I would put Channel Vision up against Leviton any time.
