31" television HELP!!!
I have a 31" Panasonic tube TV. For some reason, it has decided to cut off the sides of the image. It looks like something is trying to display it as a 32-34" mage on the sides, (maybe on the top as well, but can't tell as easily top/bottom as it is side/side). Either side of the image is cutting off. Really see it on sports. The scores and teams are often cut off enough to where you can't even see them on the sides. Any ideas what may be causing it, and/or a fix?
Thanks for any ideas.
Tv
Some times on Newer TV there is a option for the resolution that you want i some settings you can change it from like movie to full screen or the like i would play around with the video settings and see if you can change it because that is most likely the problem
