50" hitachi rear projection won't turn on
Old 03-22-08, 06:27 PM
working fine, unplugged it and moved it to a different room and plugged it in but it won't turn on. And yes the outlet is good. any ideas?
Old 03-23-08, 04:48 AM
Leave it unplugged overnight. See if it resets. If not ... did you bump it or drop it? You can poke around in there to (1) check any fuses you can find, and (2) reseat the connectors (pull 'em off and put 'em back on).
Careful -- there are potentially lethal voltages inside the case! Read the TV Safety sticky at the top of the index for this forum.
